Hi folks,
the fact that the VGN-S2HP has no built-in microphone and only the XP SP2 Bluetooth stack forces me to install the Widcomm Bluetooth-Drivers. I need the hands-free profile which is not supported by XP2 in order to connect my BT headset to my notebook. But where can I find it? Is the Widcomm diver free software? Can I install the one from my Dell Notebook on the Vaio?
Kind regards,
Falco
OK, I found it at IBM, but still it doesn't work. What's the deal? Why is there no Sony-support for Widcomm?
Please, look in the suitable link that I believe will to solve the problem.
How can I receive a file from another bluetooth device on my VAIO?
Solution:
In order to receive a file through Bluetooth, you need to configure the computer to be able to receive the file:
http://kb.sony-europe.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=5,E=0000000000017785851,K=3744,Sxi=9,Case=ob...)
I read on some hacking-forum not being able to use headset-profiles is due to a flaw in the firmware of the BT device. There is an updated firmwares, which might solve the issue. Has something to do with streaming data. Unfortunatly, it has to be cracked in order to upload it to the BT-device. Not very legit and convenient.
But it requires both cracked firmware and cracked drivers. I'd really reallylike to have headset support as well, but this is just too messy for me.
I think it is something Sony has to solve. This sucks big time. Now I have to use a old crappy wired headset to use VoIP on my very expensive Vaio, instead of a nice BT headset.
Never heard this before
Solution:
Sorry, I just tried help. Write to the e-support and post the answer.
Good Luck.
:smileyblush:
Here are the widcomm drivers with patch, I dont know if they'll work though. I can't seem to get them to work on my notebook.
Here's the link:
http://www.mp3car.com/vbulletin/showthread.php?s=65148d2c3f14f7d79bf82406d86f130f&t=35927
Good luck
hmm strange. I tried to look up the Bluetooth transfer wizard, via START = ALL PROGRAMS = ACCESSORIES = COMMUNICATION. But it's not there. I can find it via the Help and Support center "link! when i type it there.
Is there anyway I can add the program to START manually?
