my vaio seems to play up when veiwing certain sites...ie http://www.uganda-uganda.com. Is it a windows issue or a laptop issue.....some times the page does not come up properly. Also is there a problem with the blu ray player on the earlier laptops?
There is no problem on my Vaio so it would seem to be a settings issue.
Check your browser settings and check 'Internet Options' -> Secirity -> Internet is set to default values.
Also check that you have flash enabled and the latest Flash Player installed.
If that does not fix it, then come back with more details: -
What Vaio model?
What Operating System?
What Browser?
Exactly what does not load properly?
