Hi, I am trying to source a power on buttoon for a VGN-Z51XG. I'm in the UK so if anyone can point me in the right direction to source this I'd be most grateful. Many thanks.
Hi Monty2001,
I'm not sure it they'll supply the spare parts but it maybe worth contacting one of Sony's authorised repairers to find contact details Vaio support, either by clicking Support at the top of this page or use the following link:Vaio support
Under Log-in option 1: Enter your vaio models serial number, which you should find on the bottom of your Vaio.
Then click Log-In
Once logged select Get In Touch
Then Click on the Out of Warranty tab to locate the nearest location.
Hi Monty2001,
Then click Log-In
