I have a VGN-A297XP notebook with WinXP Pro and 1 gb of RAM. Do you think I will have any problems if I want to upgrade it to Vista when it finally ships?
No, but you can try the Vista Upgrade Advisor
Although it'll probably tell you none of your current software will work LOL
