Hello,
I have a Vaio laptop, model number PCG-61814M & I’m looking to replace the battery. Finding an original is proving few & far between. I’ve seen many on eBay from £18.99 all the way up to £50-£60?! All are third party ones.
Can anyone recommend a good quality one as I don’t want to buy one that’ll last 5 seconds. I’ve seen GREEN CELL batteries for around £40, abit steep for me, but if it’s worth it, then I would buy that.
I would like your option.
Cheers.
Hey. Thanks for the link. Unfortunately £90 is out of my price range.
Hi there,
It would be best to get in touch with the support team who will be able to advise you on this further here.
Best wishes,
Sean Mc
Hi Sean,
Thanks for your reply. I will see if I can do that. Cheers
Hi, did you find a cheaper battery that works? I have been looking to replace but so hard to find a genuine Sony battery. Tried couple of cheaper ones that don’t work.
