I have a Sony Vaio model VGN-AR51J laptop and have had a recent restore but have not been able to get my web cam to work since, anybody know the correct drivers or can solve this for me PLEASE... :smileygrin:
Integrated webcam? I have the same kind of problem with my VPCF11Z1E. It works a moment but if I try to update some settings of the camera the computer loses connection with the camera. Weird.
Hi richjohn and welcome
Is the camera installed correctly in Device Manager?
It should appear under 'Imaging Devices' as a Sony Webcam.
Download the camera driver as part of your Original Drivers Package here: -
http://support.vaio.sony.eu/computing/vaio/downloads/preinstalled/index.aspx?l=en_GB&m=VGN-AR51J
Try Running the DPInst32.exe file in the Camera folder (if you have a 32-bit OS)
If that installs a Sony camera OK but if not come back and we can try to install it through Device Manager by using the 'Update Driver' and 'Have Disk' method.
YES it worked a treat :smileygrin:
Thank you very much I'm now talking to my family via my webcam again...I am so happy
Thank you again a wonderful response
Glad it worked - enjoy!
