Hi, does anyone know how to check the warranty on a Vaio
Go to the esupport page and register, then log in and you should see your model and model number with when it was purchased and when the warranty runs out. Hope it helps.
Hi dssuser,
welcome to Club vaio..
Open the E-support portal, if you Do not have an e-Support account yet then click here to register, enter you registration name and password.
Once logged in select 'Manage the products you registered', then click on the + next to the model and your serial number should appear underneath..
Click on the + next to the serial number, default should appear.
Click on the + next to default to view your default warranty details..
i realise that this is a very old thread but i'm getting kind of desperate, when i log onto the e-support portal i dont see 'manage the products you registered'!! i cant remember when i bought my laptop, and need to see when the warranty runs out as it's suddenly gone tits up!!
can you please let me know where i can find the information i need?? if you can email me the results that would be very helpful! Many Thanks
