hi, i am trying to find something.
everything working fine at laptop when its connected on AC power but,
when is on battery only, cant play properly movies, sound and picture they dont sync,
something like pc has not enough power.
thanks for any answer
Hi Ronine and welcome.
Which Power Plan is selected on battery? Try changing this to High Performance. Does this solve the problem?
If it does, then check the settings for the Balanced Power Plan to see if the Settings are the problem.
With something like this, you may have to contact Vaio Support as they may have seen this before and have a fix. To contact Vaio Support go here: -
http://www.sony.gr/support/el/contacts
Enter your Vaio's Serial Number and you will be given the options to make contact.
