Hi Guys
I would like to know if there is anyway to increase the volume on the AGP i know they keep the volume low but sometimes i would like it louder
If you are still using the stock earphones which came with the VP, then this is the problem. Get yourself a better quality set such as the excellent Shure E2C ear buds (cost around £50) or Sony MDR-EX71SL ear phones (cost around £30).
Also have you upgraded the firmware yet? As although I did not notice a difference, some other forum posts suggest that their VP volume was louder following the upgrade.
One other thing, which you may have already done but nevertheless it is worth a mention:
Ensure that the Auto Volume Limiting System (AVLS), is turned off.
yes hav got new sony ear phones & checked the AVLS which is set off
If any 1 else has any ideas i wld be gratefull is there no way to change soft ware setings hav seen it about other 1,s
Are you running the latest firmware?
