HI!
sorry if someone has addressed this before, i have not had the time to thoroughly search the forum.
I own the VGN-A115B.
I am afraid that i have deleted the file in the task manager, which is running the volume buttuns, and the two little screen buttons, so for now i can not decrease/increase the volume directly and/or use the screen brightness button.
Please help me,
Thank You,
MARIN
Restart your computer, otherwise failing that visit C:\UTILS and run the UTILS.EXE file to reinstall the Hotkey Manager.
Thank you for the fast reply!
problem fixed!
Marin
