I have a VAIO desktop PCV - E11M (or so it says on the back) but when I got additional RAM, PC World said I had a VGC - V25. Anyway, having put Vista on I find that the screen does not fill the monitor. I cannot go beyond about 1024 by 768 but I think I need to be 1280 by 768. What can I do ?
Also, my Broadband connection does not now work (I am using my VAIO Laptop for this message) Grateful for any suggestions
Hi Keverstone,
Did you check that you had all the correct drivers before you installed Vista on your Vaio..?
