Hi there...
I have a VGN-FS285M and i have installed vista...the thing is that the audio buttons don't work (Fn+F3 or F4), can anyone help?
Thanks!
Hi!
You can find the drivers and utilities here:
http://support.vaio.sony.se/downloads/os/vista/upgrade.html
for the fn+fX buttons to work you need to install the "sony utils dlls",
"sony shered library" and finaly "vaio event service".
restart the comupter between each installation.
If it doesn't work as supposed after doing these three installtions
uninstall vaio event service from the control panel and then resinstal it
again (don't) forget to restart between the uninstall and install).
/Sebastian
Can any of these updates be installed prior to upgrading to vista? It would just be much easier to have my notebook as close to its current state as possible from the off without having to pick up on things that don't work afterwards.
Hi!
/Sebastian
