I hope someone can offer advice or help, I can gain access to the BBC news page on internet but I can not open the actual live screen, I get the BBC Logo and then ablank black screen with a whirlig white circle but it does not open the live screen. I am using Vista on a VGN N21M and useing Norton security. Any suggestions are welcome.It worked ok a couple of days ago I have tried a Restore to an earlier date but that does not work. Regards Carl
Hi Carl,
What you are describing sounds like the video is being blocked by a firewall or a setting on your computer. It may also be caused by a pop-up blocker.
Hopefully someone will know a simple fix but in the meantime have a look at the BBC's guide to the BBC Embedded Media Player which gives some troubleshooting tips: -
http://news.bbc.co.uk/1/hi/help/7277283.stm
Many thanks Blencogo, tied the suggested link can not find any thing to correct fault. Do you think it could be anything to do with the Router? Regards Carl (SIGM)
Can you play any other video in a webpage? What about a YouTube video?
Do you get any error messages about FlashPlayer or Java?
If you cannot play YouTube try the suggestions here: -
http://en.kioskea.net/forum/affich-21712-i-can-t-watch-video-clips
Hi Blencogo sorry for delay in replying your last post, I have managed to resolve the issue,The problemwas with a defect on the Netgear Router,very many thanks for your help. Carl
