Hi Guys,
Again me having some important issues to share with you.
I don't know why, but since few days after standby mode, Windows changes the resolution from 1440 x900 to 1080x1024. I tried to reinstall video driver, but nothing. I have also installed the new driver for nvidia video card but again nothing!
Could you help me?
PS
I have always trouble with audio settings under MediaCenter. i am unable to increase or decrease volume using remote control. The only way to do that is to use WAVE volume control. Any suggestion?
TNX
Darkmeridian75,
Question Nr. 01
Solution:
To resolve this issue, disable the 3D Maze screen saver in Full Screen mode:
1. Right-click an empty space on the desktop and click Properties.
2. Select the Screen Saver tab.
3. If 3D Maze screen saver is the one selected, click Settings.
4. Clear the check box in front of Full Screen in the Maze Setup window.
5. Click OK, Apply and OK again.
Question Nr. 02
I did not found an answer yet... I keep trying...
Darkmeridian75,
Question Nr. 01
Solution:
Question Nr. 02
Hi Guys,
Could you help me?
PS
TNX
