I have a Vaio SZ5XWN/C and have lost the ability to use the full screen and display on an external monitor.
Hi pcsmith,
The driver from NVIDIA will not install on a Vaio without a modified .inf file.
Try installing either the original driver or the Update version 7.15.10.9754, both of which can be downloaded from support.
http://support.vaio.sony.eu/computing/vaio/downloads/updates/index.aspx?l=en_GB&m=VGN-SZ5XWN_C
Alternatively you may be able to reinstall the original driver via Vaio Recovery Center – Reinstall Programs or Drivers option.
Rich
Hi pcsmith,
Rich
