there is a problem in my FE11H video card driver,
when I run Media Center, this error displays:
Your video card or drivers are not compatible with Media Center
I reinstall my video driver but error still remain,
also when I play movies, they played in lower quality.
could anyone help me?
Hi Javan and welcome to ClubVaio.
What version is the video driver you are using?
Is it Version : 4.1.100.1332
that is 8.2.9.4 as following...
Device Manager > Display Driver > NVIDIA GeForce G0 7400 > Driver's tab > Driver Version : 8.2.9.4
Hi Javan,
Have you installed the latest Nvidia 7400 driver Update
Version : 4.1.100.1332 Size : 36.1 MB
Installation instructions
I the instruction page , points that the last update just fix this:
- Adds support for additional languages
- Solves settings problems while connecting to some CRT monitors
- Solves intermittent problems involving output to TV
- Solves an issue that might cause a blue screen of death while playing back movie files or DVD
and not have any effect in my problem,
finally using system restore , solved the problem,
tanx,
bye.
Glad you've sorted your problem Javan, just out of interest what version Display Driver are you now using?
in fact this is very strange and is hard to believe,
I\m sure that I have not install any other display driver!!
this is a snapshot from my screen:
http://javan.it.googlepages.com/geforce7400.jpg
isn't it?
