i'm not able to play blu-ray anymore after i installed it to windows 7 home premium
Hi josephbe,
Did you UPGRADE to Windows 7 using an Upgrade Disc? If so you should still have WinDVD BD available to play Blu Ray.
If you did a clean install of a commercially bought version of Windows 7 then you will have lost all the preinstalled software and you will need to buy a player capable of displaying Blu Rays like WinDVD 9 Ultra or PowerDVD Ultra.
Hi josephbe,
Look for the thread entitled 'VGX series and Windows 7'.
S.
