I forgot the password for laser mouse and I can not connect this to a laptop. How do I cancel it?
Hi Britney3117,
welcome to the Sony User Community forum..:smileyhappy:
Does the guide below help with setting up your mouse.?
i have same problem
Fact is the laptop doesn't give an option of selecting pairing without a code.
Any assistance?
Hi every one
Im using that mouse : VGP-BMS21 and i forgot the passcode, too.
I tried to put some ones then i found there is one that's suitable for.
If you are using the mouse VGP-BMS21 and need to reconnect to your Sony VaiO computer. Plz try to :
Passcode : 0000
Have a nice thing !
Thank you so much!
