hi, just want to know? why is it i cant play a blu ray disc in my computer VGN FW21M? it was saying needs to updat, but when i was trying to update, there is no update available?
please help me to solve this issue.
thank you
marissa
got the same problem, lost everything when hard drive crasch, years ago. still on, now calm.
Hi marirasg and welcome.
The last published update appears to be WinDVD BD Update - 8.8.0.285 dated June 2013. Do you have this installed? What version of Windows are you using?
Since then I think Sony have stopped supporting this product which needs updates for the latest discs to be playable.
You may need to install a different BD Player - it is best to try one that gives a 30 day trial to check it works before buying.
The market leaders are Cyberlink PowerDVD or ArcSoft Total Media but there is also some free software available - try Google.
