Can someone give me some advice about the c disc, beacause I work with so many graphic big programs so that the c drive is getting full, how can I solve this, new hard drive, but don't think can put there programs, please help!!
Observe how many drives computer possesses. Usually Hard Disk isdivided in two parts : C and D. C usually is used to store programs. D for data. The drive D is larger than C,. We will say that partition comes to be a slice. If you have a Hard drive of 100 Gb. The partition C can have 30 Gb and the partition D, 70 gb.
You can change the partition of his HD with the recovery disk that comes with his computer.
Another fast and easy option and (if you have USB in his computer) to acquire an external HD. I recommend the:
http://www.lacie.com or
http://www.lacie.com/uk /
you can acquire a HD of good quality and low cost.
I hope to help....
REALLY thanks for your advice, but your advice for a external harddrive isn't I think for the programms, so you mean first do a recovery with changin the size of the partitions and then use the extern drive for back ups.....
Yeah thats what he means.
Makes it easy to store other stuff too as well as backups.
A second hard drive is always a good idea, along with frequent backups onto CD or DVD.
True
