hello all,
I have re-install clean xp pro.
but now, when I click shutdown or stand-by .....the system hibernate.... why ?
please help me
antonello
hello all,
please help me
antonello
ok, but what I must change in power management ?
I have tried to turn-off the intergrate webcam.... and my pc shutdown ok.... if enabled the webcam.... the pc not shutdown.
Where I found the power management of integrate webcam ?
antonello
Hi Antonello and welcome.
Download and install this Hotfix from Sony USA - it should solve your problem.
thanks, but my xp is in italian language... this hotfix not install...
help....
You may have to contact Microsoft for the Hotfix KB909667 in Italian. I am not sure if it will work if you change your default language to English (United States) and change it back afterwards.
Alternatively, try the workaround:
1. Click Start, click Run, type devmgmt.msc in the Open box, and then click OK.
2. In Device Manager, expand Imaging devices.
3. Right-click the USB camera, and then click Properties.
Note The USB camera is typically located under Imaging devices in Device Manager. However, the camera may be located elsewhere, depending on the device. Contact your hardware manufacturer for more information.
4. Click the Power Management tab, and then click to clear the 'Allow this computer to turn off this device to save power' check box.
thanks again, I have tried also the workaround tips....but in my camera properties there is not a power tab .....
I am crazy....
antonello
I have tried to disable the power mang. in the last controller usb connected to the web cam. it seems to work.
I hope !
many thanks...
antonello
