Im looking at purchasing the following memory: VS1GSDS533D2
Spec:
1GB Corsair, DDR2 533MHz, 128Mx64, non-ECC, 200 SODIMM, Unbuffered, CL4, Lifetime Warranty
Will this work or do I need to by the corsair OEM specific or official sony stuff?
Regards,
James
http://www.crucial.com/
They have a list with VAIO-models. Select your own and you will see RAM which you need. For a good price and the same limited Lifetime warranty like Corsair Ram.
Sony's RAM is too expensive and not within there own specific hardware specification.
Many thanks.
No problem.
There seems to be little problems with ClubVaio. I was sure I posted only one time.
