Hi Folks,
Any comments, suggestions, pointers to the following most welcome:
Hi nagorsi,
The Base System Device will almost certainly be the Ricoh card reader/writer. There doesn’t seem to be a Windows 7 driver released by Sony for your model, so if the original Vista driver fails to work then you will have to try the manufacturer’s site:
http://ricoh-sd-mmc-host-controller.drivers.informer.com/
I have no experience of upgrading to SSD but notice that there is an updated SFEP driver listed for you model under ‘latest Vista downloads’ – apparently this addresses a BSOD problem with a Windows 7 install. Whether this is the same problem you are experiencing I have no idea but it is worth a try.
http://www.sony.co.uk/support/en/product/VGN-NS10L_S/downloads/EP0000228472_8630
Rich
