hi, happy new year to all of you.
i bought a Sony Vaio VGN-FS315H a few days ago and i am trying to see some films, but the image is of a very bad quality. i know the problem is not of the video file because i have experimented it in two other computers. the image appears highly pixelated. i have installed the latest video codecs and still no progress.
i thought vaios were great sound and image tools, but this is making me think that's not really true. can you please help me and tell me if there's something i'm missing here?
thanks in advance for your help.
Try to install RealPlayer 10, i had the same problem, but it improved vastly when i installed the latest mpeg2 codecs (from nvidia) and used real player.
DVD, Xvid etc all look much better now
I disabled the Video Mixing Renderer which was not supported by graphics card. The result was increased sharpness.
But I have an other graphic chip. So, try itself.
Just disable VMR in your DVD encoder settings and your favorite player.
Maybe that's your problem.
Do you have WinDVD which came with the VAIO installed?
yes, but my problem is not specifically with dvds, but with DivX and XviD.
i think my problem should be in the graphics card. can anyone tell me where can i get the drivers for the nvidia geforce go 6400 card?
hi!
click thi slink to download vlc media player for windows.
http://www.download.com/3001-2194-10410655.html
at the top of the page it say thank you for downloading and directly underneath it says vlc media player. click the vlc mediaplayer to download. i use it a lot and have so far had no probs. hope this helps
thickloaf.
if the link fails then go to www.cnet.com and search for vlc.
2/3's of the way down the page you will see a link for vlc media player for windows, click that link and follow instruction.
The Geforce Go drivers have not been updated for ages, if there's no new one on VAIO-Link then you can try the Omega Drivers but Sony don't support them
