VGN-FS315E mouse problem
ASH1982
Visitor
My left mouse button no longer clicks... I mean it works fine but there is no "click" noise from it... its totally silent and dsnt feel like its moving anymore yet still functions
The right button is fine and so is the touch pad :cry:
10 REPLIES 10
profile.country.en_GB.title
kee-lo_
Member
The spring has gone in it, happened to me too
ASH1982
Visitor
Can I get a new spring?
ASH1982
Visitor
bump
robpaxton
Explorer
Try contacting Nextronics - it is a US based company but they will ship to the UK.
Contact them by e mail and let them know your model and the problem you are having. Chances are that it isn't a spring but a tiny click type swich attached to a subassembly. If so then you will need to replace the small circuit board.
ASH1982
Visitor
They dont list the VGN-FS315E :cry:
profile.country.GB.title
Thalamus.
Champion
Hi ASH192,
If you contact Nexttronics by Email, as Rob mentioned, listing your model number and the problems you're having, hopefully they will reply and be able to help you further.. :slight_smile:
ASH1982
Visitor
well ive emailed them a few times and I crnt even get a responce off them
any more ideas?
ASH1982
Visitor
Anyone :cry:
George.m
Visitor
well use an externtal mouse or change the settings to be able to use only the touch pad(without the buttons) :smileyhappy:Dont worry be happy :slight_smile:
