Hello everybody
I've a VGN-FS115M XP home SP2, Bios & Software updated.
I installed a PCMCIA smart card reader schlumberger Reflex 20 with last drivers (3.6.0.1) . As soon I insert a smartcard, everything freezes (without any message).
This smartcard reader worked fine previously on my Toshiba notebooks.
Any idea ?
thanks in advance
Try googlinjg the name of the PCMCA card reader - as VAIO Link doesn't seem to have any new drivers.
Thanks
But I already looked for the device drivers thru Google and I installed the last drivers delivered by the manufacturer.
The smart crd reader worked on my previous toshiba M30 notebook. (XP SP2 too). So it seems to be a Vaio-related problem.
What type is it, Type II or Type III?
Can you not use a USB reader? Would save you a lot of money.
Yeah thats why I like my exec case for my notebook, pleanty of space for that sort of thing.
I wish Sony would opt for more media readers in the laptops like they did with the RA104.
This may help you:
http://support.microsoft.com/default.aspx?scid=kb;de;279256
It solved my PCMCIA problems on a FS195XP ...
i got the link from another forum...
