hello i have the vgn-fe41s and i have downgrade from vista....to xp version.....and my camera dont work....anymore...search on the forum...and download...another driver...from another model...but when im try to install it....its say error the driver failure to update..the camera cature...utillity when i open it it say no camera input.....
any ideas??
windows xp home edition sp2-sp3
thanks in advance
The camera works differently with XP.
You need the same driver as you used in Vista - the same driver works for both XP and Vista - you need the VGP-VCC4 driver from your original driver set.
The Vaio Camera Capture Utility is a Vista program - you do not use it with XP. Instead you need a XP version of the VAIO Camera Utility. With the XP version of this utility your camera will appear and can be opened from My Computer. You need to download Version 1.0.00.12270 from the Original Utilities Download for the FE31 here: -
http://support.vaio.sony.co.uk/downloads/preinstalled/preinstalled.asp?site=voe_en_GB_cons&c=0&s=VGN...
