Hi Keat,
Your FE41S should take any compatible 'Socket M' processor - so T7200, T7400 and T7600 should be fine with your 945PM chipset.
The only concern is the extra heat generated, so think carefully before fitting a T7600.
The Socket M models have been discontinued for some time and you may have to search around for one.
Hi Blencog,
Thank you very much for your reply. I think in this case is better I upgrade to :
The CPU from VGN-FE41Z is :
Processor: Intel Core 2 Duo Mobile T7200 (2.00 GHz)
L2 Cache: 4 MB
Since the VGN-FE41S almost the same as VGN-FE41Z. Do you agree with that?
Best Regards,
Keat.
Hi Keat,
