When I first bought my FE31H a couple of years ago now, all the Fn functions worked OK. But, since then I have clearly done something 'wrong' as the only ones that I can get to work now are /, * and +.
I have noted the suggestions for doing this on an FE11S under Vista, but do not recognise any of the files in the VAIO download screen for FE31H under Windows XP.
Can you help me please?
Hello again...
I think I've managed to solve the problem myself now.
I downloaded the original utilities zip files for Windows XP and installed them in the order given by another (expert) member for the FE11.
I had no C:\Utils folder (not sure if I had inadvertently deleted it, thinking that I didn't need it!) so the exercise was straightforward.
All's well that ends well. Thank you and goodnight...
glad you've managed to solve your FN key problem..
