VGN-FE21S Cleaning
TurboVaughan
Visitor
VGN-FE21S Cleaning
My Vaio is starting to run pretty hot and I think it's time to clean the fan. Can anyone direct me to a manual or any instructions on how to get access to the fan for cleaning?
Many thanks
8 REPLIES 8
profile.country.de_DE.title
itbroker
Visitor
I did a research at Internet and I found 02 (two) guides...
I really liked the guides because you will find a comment like...
IF YOU DON'T HAVE SURE ABOUT WHAT YOU ARE DOING; DON'T DO IT...
Take a look...
From Notebook review here...
and How to Clean the Dust from an Overheating Sony VAIO XXXXXX modelv here...
The second one is NOT from your model, but still a very good guide.
Good Luck !
... and remember IF you are not secure about How-to-do-by-your-self, ever you can spend a feel bucks and try a professional service, I mean your warranty (by example).
:smileygrin: :smileygrin: :smileygrin:
TurboVaughan
Visitor
Thanks ITBroker. There's a lot of good advice in there. I'm going to the computer shop now to pick up my can of air.
itbroker
Visitor
Okidoki and Welcome to ClubVaio :wink: !
profile.country.GB.title
Thalamus.
Champion
Hi TurboVaughan,
what is the normal running temperature of your Vaio..?
If you're unsure PCWizard is a handy application to check your Vaio’s temperature. To download use the following link: PC Wizard
TurboVaughan
Visitor
Hi Thalamus. I have a copy of Speedfan. That tells me my HDD is running at 33C (little green tick) and my two CPU cores are running at 55C and 57C (bright red and yellow flame) :slight_frown:
Thalamus.
Champion
Hi TurboVaughan,
those temperatures do not seem to excessive but if you want to clean out your Vaio I have sent you guide via Private Message, use the following link to View your messages: Private Messages
TurboVaughan
Visitor
Thanks for your interest Thalamus and for the guide.
You don't think those temperatures are too bad? It was SpeedFan's flames that made me think it might be a problem, but I have since done a bit of reading and can see that its just a matter of configuring the program for my specific motherboard/setup. So when should I be worried? 60C? 70?
I once had a chat with a Dell technician and he said the single biggest problem for Dell notebooks was dust causing overheating leading to component failure. He said it was important to keep your notebook clean. I always thought that was the kind of good advice that was a little too hard to actually follow :slight_smile: Maybe, armed with your guide, I'll have a little look inside and see how it looks after all.
Many thanks again
Vaughan
Thalamus.
Champion
I would say between 50 and 70°C would be ok depending on the tasks your are running, gaming would probably be higher..
I believe around 100°C is the maximum for dual core CPU's..
