I have a VAIO VGN FE11S.
I have the problem that my screen goes black every time a java aplication stats. I can only see the mose on the black screen. The system is ok it is working but only the screen stays black.
I found out that JAVA is causing this prolem. So i have turnd of the hardware acceleration and then i can start JAVA applications again.
How can i run Java with hardware acceleration?
got the same problem here.
I tried all the tips but there is no change. It does not work.
It would be very nice if someone from the sony support team could do a reaction on that thread because it is a really critical Error!
A brand new notebook which can not run Java Applications!!!
I don't think this is a Sony problem, but a Sun problem...
OK, after I did a lot of investigation, i found a workaround for that problem.
It is of course a problem of the Sony Graphic Driver togheter with a problem with directdraw and java.
http://forum.java.sun.com/thread.jspa?forumID=513&threadID=305813
After disabling direct draw functionality, java is working.
Workaround:
goto display options-->Problem..handling--> put the slider to the left side.
Now games wouldnt work, but java does.
SONY!! PLEASE FIX UR Graphic Card Drivers!:smileyangry:
