Is it possible to get replacement keys for the VGN-CR21S series? Seems like the key support is broken as well as the key. I believe there is no local service (in Finland), so I don't want to send the computer to Belgium for repair.
Thanks in advance
Btw. I would have used search to check if this has already been covered, but the search doesn't work
