I've had an s-series VGN-SIHP for 6 months now and it has worked fine.
Recently when I power up the laptop the machine does not start. The fan starts and you can here internal noises but the VAIO symbol does not appear on the screen. The only way to get the laptop on is to power on/off via the pwr switch 10 - 20 times, eventually the VAIO symbol appears on the screen and it starts as normal.
Can anyone offer advise on this, Cheers....
I would have VAIO Link check it out.
it looks like there is hardware fault either contact vaio link or take the risk to try to fix it ur self. but if it is not the ram or HDD and something inside the laptop that you dont have acess to easly then contact vaio.
mine does this when my external HDD is pluged in. when i remove its fine, then just plug it back in after
