Hello!!
My nopebook power settings in windows xp pro sp2 are to hibernate the pc when the lid is closed.
This works perfectly the first time, then resumes when the power key is pressed.
However - if the machine is asked to hibernate again either by shutting the lid or the keyboard shortcut, it freezes on the blue windows xp logo "preparing to hibernate" screen.
any ideas?
-the swan
thanks for the link, but this refers to win 3.1, plus their fix seems to be turning off hibernate all toghether which can't be right.
it does hibernate the first time, but the next time it's tried it fails and needs to be rebooted.
i'm thinking maybe windows is trying to end a program or service that can't be ended?
Ack wrong thread!
Have you checked Windows Update for a hibernation patch?
It's a bit extreme selling it.
I can't find a decent reply either which winds me up.
Do you have a lot of space free on C:?
Well if the hard disk doesn't have the space to store whats in RAM it cannot do it properly, hence it's reboot.
Yeah you can log it with esupport.
