Hello all, hope someone can help me.
There are drivers available for raid in the drivers section for the AR51m, but I can not see how to enable raid in the BIOS...
Is raid supported or not on the AR51m?
If it is, how do you enable it?
Many thanks
Hi iziizi,
according to the specifications your AR51M HDD drives are not set up as RAID..
Use the following link to view the specifications: AR51M Specifications
Hi iziizi,
just to let you know Sony have removed the Raid Intel SATA Driver 7.5.0.1017 update, thanks for bringing it to our attention..
