Is there anybody successfully downgrade it to xp? Please share your successful experience here.
Hi modekiller,
welcome to Club Vaio..
Beware Sony will only support Vista on your vaio, therefore if you have a problem with your Vaio and you need to contact vaio-link you will probably have to reinstall Vista, also you will loose all of the applications that came pre-installed on your Vaio..
If I where you I would try and stick with vista..
However if your sure that's the route you want to take, have a look at Blencogo's post in the thread using the following link: XP Drivers for VGN-AR61E
And you may find these thread of interest..
Full instructions to downgrade an AR31M from Vista to XP Pro
Audio drivers for downgrading to xp on AR51M
