Hi, I bought Logitech Z-5500 speakers and I want to connect them with my vaio using optical connection. I don't know what cable I should buy cause optical output in my vaio looks like normal 3.5mm jack connection. In Logitech Z-5500 optical connection looks like that:
http://cgi.ebay.co.uk/10M-TOSlink-Optical-Cable-Lead-Digital-PS2-Xbox-5-1-UK_W0QQitemZ250254206422QQ...
Please tell me what cable I should use cause I'm confused.
Sorry for my english
Regards
Lukas
You require a Tos to mini tos connector as the one in your VAIO is a smaller version of the one on your speakers. Just search google or maplins and you will find the connector you need.
This thread may be useful.
Cheers mate, I found this on eBay hopefully get it tomorrow.
Regards
Your welcome
