hi,
I have problems with my wireless connection.
When there insn't traffic in the connection the adapter goes downn and I lose the conection to internet.
I have to "Repair" the adapter and then the wireless connection runs well until it will gone down again.
could you help me?
thanks
juanjo
check the settings in your router configuration for disconnecting after an idle time. maybe this value is set to a small value and is causing your connection to drop. try increasing the idle time and see if it helps.
