Hello to all Vaio users
i wish to upgrade my 317m's memory to 1GB.
now, it has its original memory (ie 2x256 MB DDR2 400 PC2-3200).
i saw many different informations about this computer's memory, so i ask for a little help in this thread
first, i could read in user's manual that maximum memory is 1GB, on this computer. but in Sony knowledge base, it says 2GB
...who should i believe ?
second, i could notice that this computer is equipped with Intel 915 PM chipset (that means, theorically, 2GB max of DDR2 533).
so my question is the following, can i put DDR2 533 MHz (PC2-4200) in my Vaio ? If yes, can i put 2BG, and will it run at 533 MHz ? (because now i have 512MB DDR2-400 memory)
in advance, thanks for your help
regards
Maelstrom
If someone tried with PC2-4200 memory, and could check it's running at 533 Mhz (and not 400), please tell me if it works
i would like to be sure before buying
thanks a lot in advance
I had 512mb in my A217M (2 x 256mb) and I ordered a 1GB module from Crucial. Just swapped it with one of the old 256mb modules and away it went. 1.25GB memory now, makes quite a nice difference! Defintely worth the money
Oh very nice
thanks for the information
so, mixed memory modules are wroking fine...that's a good thing to know
everyone around here seems to like crucial...i should follow your advice, and buy my memory there. seems working fine with the Vaio :smileygrin:
thank you again !
Thanks a lot again, Thalamus
your advices are always useful
i could find some information on several commercial sites, saying this Vaio is shipped with pc2-4200 memory...but Sony doesn't seem to sell this kind of memory...mmm i will investigate more
Thanks a lot again, Thalamus![]()
Oh guaranteed...i see i see
that's great, i understand better why everyone likes crucial now![]()
seems to be most reliable choice, and best quality/price ratio (sony's "official" memory is really expensive)
again, thank you a lot, Thalamus, for all your help and advices![]()
now, i know where to buy
