After connecting to usb port on left side, it just died, are there any fuses or protectors that may have tripped?
18 days out of warranty!!
thanks for any help
Ouch:smileycry:
Doesn't sound too good.
Clutching at straws but:
Have you tried pressing the little recessed "reset" button on the underside with a cocktail stick or something similar for a few seconds?
Or removing the battery for a few minutes?
thanks, took back and battery off, and its now ok.... but.. mousepad not working, guess who broke the pcb cable, any tips to replace or repair, suppliers etc.
cheers coulddnt find reset button though, is it hidden?
thanks for your swift reply, i will see if i can repair it, if not, i will get a new one, thanks.
why is it not possible to buy parts in the EU?
