I got my Vaio pocket last night and when wondering what to do about a case (I'm not fond of the huge PDAir case or the clip-less Sony case) I noticed that the Vaio was roughly the same size as my Blackberry 7100g. So naturally I slipped the Vaio in the Blackberry case. It's snug, but it fits great. And, what works so well is what it leaves open on the Vaio. The screen is completely covered, so it's safe. The case leaves a portion of the touch pad visible, which gives you access to the play/pause/volume buttons while in the holster. It also does not impede with the headphone jack in any way. And, with a little snip, the power/hold button is available. It's made out of a black padded canvas material (I don't like leather, so this works for me) and the clip for your belt is slim and unobtrusive, making the overall profile much smaller than the PDAir case.
I'd post a pic, but my camera battery just died and I'm at work.
Plus it's only $14.99
http://www.shopblackberry.com/_blackberryaccessories/cgi-bin/pd.cgi?page=product_info&category=Carry...
Or you can get it on eBay for $.99 plus $6.50 shipping. (ends October 9)
http://cgi.ebay.com/OEM-ORIGINAL-RIM-BLACKBERRY-CASE-POUCH-7100v-7100x-7100_W0QQitemZ5815204661QQcat...
Great tip, I personnly made myself two cases out of old one I had (one for a cell-phone, another for the iPod), I'll try and post a pic here, although pictures of one of them is shown there:
http://www.digi-topia.net/test.asp?testid=23#gal
(pictures at the bottom of the review).
