hi there woundering if the ps2 can be directly connected to the vaio vgc-v2m, using the the cabels (red, white, yellow)?
OR
Do i need a converter of some sort?
I think you can do it like this.
Whats at the other end (PS2)?
well wana basicly play my ps2 on my sony vgc-v2m screen.
is that possible and if so how :S
Yes but what connections do you have from the PS2?
well depends what connection i'm supposed to use?
currently i plug my ps2 in to my tv using the cable provided, (red, yellow and white).
Does the V2 have that sort of connection?
yes it has however even if i plug it in its not picking it up for some reason.
Strange, you should see a picture on one of the external channels.
hmm how do i access the external channels :s i'm new to this stuff.
As you Have the red white and yellow cables fitted , Open your TV , Then select video impute on your channel select option . This should show your PS 2 as A Real time Video Impute , But I¿m sure Recording your games as you play them Is an Option open to you also .
I would Hope This Helps ?
