Hi I have a VGC2M can you tell me is it possible to play audio through external speakers or surround system and if so whatb eqiupment or cable you could suggest.
Danny.
I think it only has 2.1 output, so you'd need a 7.1 surround USB card and the speaker system to go alongside it
hi, at the moment i'm using a cable from the headphone socket (3.5m jack) to connect to the aux socket on my amplifier. ie using a 3.5 mm jack to phono (red/white) cable.
It really bugs me how poor the connectivity is on these machines.
You could only use this method to connect to surround system, but still not truely the surround connection. This only thing to do that is to buy a USB External Sound card like Creative Extigy.. something like that.
