Hi
just wondering if anyone else experiences very slow up times on this dvd drive.....had problems with this drive and sony replaced it under warranty ...but always seems very slow in opperation.
pat
No James, best to use decent media....
it can take upto about 30 seconds for the drive to display the contents of a cd from closing the drive...and if its a dvd data disk with a large amount on it it seems like 2-3 min to display the info and also this really slows down my whole system.
Try using a TDK DVD disk instead of the media you have been using - does this reproduce the problem?
What software are you using to author (burn) DVD disks?
Sounds like it needs seeing to.
