hi all!
just wanted to know if its normal that my FE21s goes up to 75 degrees at 100% cpu load and between 40 to 60 degrees at normal loads .
thx!
75 degrees is a bit high but can probably be explained by the warm weather.
It's hot here but I bet it's even hotter in Tel Aviv !
65 degrees under normal usage is OK. You will know if it is overheating as your Vaio will become very slow and unstable.
thx for the answer!
and yes this summer is very hot in tel-aviv , can go up to 40 degrees:)
Yeah it's very hot in Tel Aviv, my uncle's family are there and it's sweltering.
So 75C at 100% load isn't bad at all
