Wondering if anyone can help.
Have just purchased the above model which has a numeric keypad.
Have noticed that you can either press NumLk key to type the numbers, or NOT press NumLk key if you want to use the Home and End keys within the pad. There are also separate Home and End keys at the top of the keypad which can be used.
I wondered whether the Home and End keys (within numeric pad) can be used in conjunction with numbers, or whether it is a case of one or the other. Or will some other setting allow both to be used?
Hope that makes sense!
Thanks for any help.
