Hello everyone!
I know that i am not the first person to submit this kind of post regarding the Sony Vaio VPCF11S1E laptop series and their overheating problems but i have some questions towards the community.
Taking into consideration all other posts made i would like to ask the following:
1) It is true that the cleaning of the fan can help it's funktion. But how often should one clean the fan? When should i understand that it's time to replace the fan? Can the replacement do a big difference in overheating and silent running?
2) How possible is it that i may have to change the thermal paste of the CPU? Is this a major issue regarding the fan problems?
3) Will a cooling pad help my laptops effectivity? What kind of a cooling pad should i consider buying?
I am looking forward for your answer.
Thanks in advance,
Diogeness
My Sony had overheating problems - fan on full blast then the laptop kept shutting down. I diagnosed this to the fan being clogged up with dust. I opened the laptop up, removed the dust around the fan (a fair amount of it!), put it all back and Presto! Overheating issues resolved & running fine again. Don't touch the CPU paste.
