I recently bought a new Vaio and after a few days I discovered a problem with my left internal speaker. At first it made some weird noises and now it's not working at all. I checked the sound settings and the balance is ok, the sound is enabled on both speakers. I also did a complete restore of the system to check if it's not a software issue. Is anybody out there that has the same problems as me?
Hi invaderzym,
welcome to Club VAIO..
If the problem is still there after a complete recovery I suggest you contact vaio support, to find contact details for Sony Vaio support..
Open Vaio support, either by clicking Support at the top of this page or use the following link:Vaio support
Then Log-in and select Get In Touch
