Hi there, just wondering what pin configuration the microdimm on the s1xp is. All of my documentation doesn't say a thing. Is it the 172 pin config ram this notebook takes?
Thanks for any help.
Hi balsaq,
According to Crucial.com your S1XP takes 172 pin MicroDIMM 333Mhz modules..
Sony only states microDIMM - 333Mhz
Thanks alot for your help!
You're welcome..:smileyhappy:
