Major problem. The computer froze and when I restarted it I got a black screen with the message "operating system not found". Have no recovery disc. The computer is only six months old. What can I do and what happened?
I had Windows 7 on the computer. Don´t care about the files, there is a backup on them, but I don´t have any backup on the op system.
Hi MonicaAnd,
Your vaio made need a repair so I suggest you contact Vaio support by clicking on the following link:Vaio support
Then under Log-in option 1: Enter your vaio models serial number, which you should find on the bottom of your Vaio.
Then click Log-In
Once logged select Get In Touch
Hi MonicaAnd,
welcome to Questions & Answers..
Most Vaio's has a hidden HDD recovery partition so you should be able to recover your Vaio back to the original installed OS and programs just as it was when you first used your Vaio.
To do this Start your Vaio and when you see the Vaio logo screen press F10 repeatedly this should start the recovery utility and allow you restore the Sony supplied OS and applications..
Hello
Thanks for your answer. I have tried this but it doesn´t work. The same message comes up......
Hi MonicaAnd,
Then click Log-In
